CW
Light industrial motors, single and three phase, with rolled
steel body construction, available in B56 and IEC. Customer
specific versions available, offering special electrical and
mechanical requirements, including 2, 4, 6, 8 and 12 pole, 0.18
to 2.2kW continuous rating, and up to 4kW short term.
• Full service and parts available
• Multi and variable speed options
• Multi and resilient mount types
• Non-standard voltages and frequencies
• Special shaft designs and materials
CT
The CT series includes the CT52 Fridgemaster, CT72&75 Pool &
Spa, CT76&82 General Purpose, and CT85&90 Air Movement motor
ranges, all of which can be designed and built to customer
requirements.
• CT52 : 13 to 60W, efficient PSC design, reversible, totally
enclosed, universal mounting
• CT72&75 : 370 to 1500W, certified AS/NZS60335, NEMA & B56
flange options, low noise, stainless steel shaft, screws and tie
rods
• CT76&82 : 180 to 370W, light industrial applications
• CT85&90 : 40 to 1100W, single & double shaft, low noise long
life bearings, dynamically balanced, resilient mount, PSC
design, auto reset thermal overload
• Accessories and spares available
MN & MT
Single phase, cast aluminium motors. 2, 4, 6 and 8 pole, 0.09 to
7.5kW. CSCR and PSC versions.
The MT series features a multi-mount arrangement incorporating
bolt on feet or pad mount configuration
• Light weight
• Single phase
• B3, B5, B14, multi, and pad mounting
• Ideal general purpose motor
• Top mounted terminal box standard (rotatable)
SLA
Three phase, cast aluminium motors. 2, 4,6 and 8 pole, 0.09 to
11kW, ideal for the OEM market.
The SLA series features a multi-mount arrangement incorporating
bolt on feet or pad mount configuration.
• Light weight
• Ideal for alloy gear boxes
• B3, B5, B14A, multi, and pad mounting
• Multi speed available
• SLA is MEPS (2002) compliant (Eff2)
SGA & HGA
Enhanced performance cast iron three phase squirrel cage motors.
Low temperature rise through conservative design. 0.37 to 315kW,
frames 71 to 355. 2, 4, 6, 8 and 10 pole. IP55 protection.
• 2 year warranty
• Robust construction
• Generous service factors
• Hazardous location versions : Ex e, Ex n, DIP
• Mining spec versions
• Smokespill applications
• Multi speed
• Left hand and top mount terminal box also available
• SGA is MEPS (2002) compliant (Eff2)
• HGA is MEPS (2006) compliant (Eff1)
PPA & PPC
Premium motors. High efficiency, cast iron construction, IP66,
three phase, 0.55 to 1000 kW. 2, 4, 6, and 8 pole. Australian (PPA)
and CENELEC (PPC) kW/frame allocations. Complies with MEPS high
efficiency standards as per AS/NZS 1359.5-2000.
• Class H insulation
• Thru flush grease relief valves
• Low noise
• 20 year design life
• Epoxy paint
• AS/NZS 1359 (IEC 60034 & 60072) dimensions
• Frames 80 to 450
PPD
Hazardous location, Ex d, Zone 1, Group I & IIB, T4 temperature
class motors. Cast iron, IP66, three phase 0.55 to 90kW. 2, 4, 6
and 8 pole.
• Class F insulation
• Low noise
• Meets IEC standards
• Foot or flange mounting
• Up to 1100 volts
• Complies with AS3947-2
